AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Fading away results above command line
6 REPLIES 6
5960 Views, 6 Replies
Hi guys,
I have small, but annoying issue with AC 15 LT for which I couldn't find solution in previous topics. After execution of command, result is presented above command line. After a few seconds that result is starting to fade and finally disapears. How to turn it off? Or is the a way to adjust that time before it starts fading? For example in TrueView 15 there is no such problem.
6 REPLIES 6
rkmcswain
nestly2
If you don't want the command history to appear above the command line,  Click the "wrench" icon at the left of the Command line then change "Lines of Prompt history" to 0  (CLIPROMPTLINES sysvar)
info7UL9W
in reply to: rkmcswain
Useless response.  He provides link that not only doesn't have the answer, but has the questioner complaining that he can't find the answer.  If you don't have anything constructive to say, don't say anything at all.
rkmcswain
in reply to: info7UL9W
Care to elaborate? What was a useless response? The one marked Solution? @info7UL9W
R.K. McSwain     | CADpanacea | on twitter
info7UL9W
This link:
<>ory-fade/td-p/4839611>
http://forums.autodesk.com/t5/autocad-2013-2014-2015-2016/command-line-histo
pendean
@info7UL9W wrote:
This link:
The last reply to that post, not tagged by anyone as an answer, is one of many solutions, here is the direct link to it
https://forums.autodesk.com/t5/autocad-forum/command-line-history-fade/m-p/11825531#M1100922
And here is a visual of that solution
The other solutions are in the first link in the post you were replying to.
Technology Administrators
