AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Fabhrication in LT
6 REPLIES 6
JamesWMiller
519 Views, 6 Replies
Fabhrication in LT
Is AutoCAD Fabrication mep compatiable with AutoCAd LT & Revit LT?
James Miller
6 REPLIES 6
in reply to: JamesWMiller
As long as it is .dwg file extension you can open it in Autocad and .rvt for revit.
Cheers!
If you find this helpful you can hit "accepted solution" and "kudo"
pendean
What do you want the word "compatible" to mean?
Emmsleys
To add;
You could always try running the trial versions of AutoCAD LT or AutoCAD to see if it works for your project tasks.
Do you have sample files you'd like to share?
Sarah Emmsley
Technical Support Specialist
Emmsleys
You can download a trial version from the links below.
Try AutoCAD for 30 days
Try AutoCAD LT for 30 days
Sarah Emmsley
Fabrication CADmep requires a Full version of AutoCAD to Load, so you could not use Fabrication commands within AutoCAD LT.
However you can view fabrication drawing in AutoCAD LT if you have the correct fabrication object enabler.
Also remember fabrication content is in 3D, so you will have limited tools to navigate the 3D model in AutoCAD LT.
Justin Doughty
Cadline Ltd.
Blog | Twitter
Emmsleys
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Post back with any updates.
Sarah Emmsley
Technology Administrators
