Is AutoCAD Fabrication mep compatiable with AutoCAd LT & Revit LT?
As long as it is .dwg file extension you can open it in Autocad and .rvt for revit.
Cheers!
If you find this helpful you can hit "accepted solution" and "kudo"
To add;
You could always try running the trial versions of AutoCAD LT or AutoCAD to see if it works for your project tasks.
Do you have sample files you'd like to share?
You can download a trial version from the links below.
Fabrication CADmep requires a Full version of AutoCAD to Load, so you could not use Fabrication commands within AutoCAD LT.
However you can view fabrication drawing in AutoCAD LT if you have the correct fabrication object enabler.
Also remember fabrication content is in 3D, so you will have limited tools to navigate the 3D model in AutoCAD LT.
Following up on your thread, were you able to find a solution or a workaround?
Did any of the posts in the thread help with the issue?
Post back with any updates.
