AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
Extracting Attributes
3 REPLIES 3
382 Views, 3 Replies
Can somebody extract the attributes out of this dynamic block working with 2008LT, and show me how to do it.
greetings Cor
3 REPLIES 3
tmccar
Have you tried ATTEXT?
pendean
In addition to other replies, you can start here, there are even more tutorials online at at YouTube http://www.cad-notes.com/how-to-extract-block-attributes-in-autocad-lt/
Emmsleys
Hi @Anonymous,
To add to this thread you can also take a look at the following.
To Extract Attribute Information
  1. At the Command prompt, enter attext.
  2. In the Attribute Extraction dialog box, specify the appropriate file format: CDF, SDF, or DXF.
  3. Specify the objects to extract attributes from by choosing Select Objects.
    You can select one or more blocks in the drawing.
  4. Specify the attribute template file to use by entering the file name or by choosing Template File and browsing.
  5. Specify the output attribute information file by entering the file name or by choosing Output File and browsing.
Sarah Emmsley
Technical Support Specialist
Technology Administrators
