exporting autocad drawing to pdf-preventing adobe preview from opening
Can someone please help! Every time I export an autocad drawing into adobe, pdf form, it opens a preview of the drawing in adobe.  This takes a lot of time when all I want to do is simply resave the pdf in another folder-not view it. Does anyone know how to turn off auto preview of the adobe drawing?
h_s_walker
Welcome to the Forums
Are you using PUBLISH or the DWGtoPDF.PC3 file?
If PUBLISH there is an option which says OPEN IN VIEWER WHEN DONE. Make sure that is not ticked.
If the DWGtoPDF.PC3 file do the following
At the command line type PLOTTERMANAGER
Open the DWG to PDF.PC3 file
Choose the DEVICE AND DOCUMENT SETTINGS tab click on CUSTOM PROPERTIES.
In ACCESS CUSTOM DIALOG click on CUSTOM PROPERTIES...
At the bottom of the dialog box in ADDITIONAL OUTPUT SETTINGS make sure that OPEN IN PDF VIEWER is not ticked.
Now click on OK to close the boxes and save your settings
Howard Walker
Left Handed and Proud
