error saving PDF file , PDF file file is open or uneditable
on the 2018 version of autocad, the publication of plots in PDF works
on the 2020 version, I have this error message which appears randomly. Sometimes it works, then on the same file it doesn't work anymore.
The message is "error saving PDF file , PDF file file is open or uneditable"
I tried the different solutions proposed in the autocad help but it does not work
Do you have an idea to solve this question?
pendean
Community Legend
Community Legend
Not seeing that here: how frequently does it happen? "randomly" usually means it may be a specific driver issue, problems with the files, or problem with accessing the location the PDF file(s) are created. All things hard to decipher remotely like this.
