Error "parsererror[object Error]" activating Autocad LT 2016 Trial copy
I’ve installed Autocad LT 2016 Trial version and i getting an error trying to activate the trial copy: “parsererror[object Error]”
I’m sure that the user and password are correct (I can login the support portal). Already change the password to remove special characters but still no success.
Does anyone have the problem? Any ideas to overcome this situation, I only need to test the hardware with the new Autocad LT version.
Thanks a lot.
Rafael
pendean
Community Legend
Community Legend
The trick used for Maya Trial didn't work for me, I've removed all the special characters from the password, now only have letters and numbers, but doesn't work. Thanks for the tip anyway.
Rafael
grace.liu
Hi Rafael,
Welcome to the Forum!
We understand you encountered the log in issue when use the trial version. May I confirm with you which browser you are using? Would you mind trying to download Firefox and seeing if things work there? Sometimes the issue was cause by IE.
Hope it could help you.
Grace Liu
Great.
I was having the same problem with a Trial Licence.  When I removed the # frommy password it worked fine.
Peter
