Entering text, program shuts down
Message 1 of 12
When trying to enter text the program shuts down with message that AutoCadd cannot continue. I have uninstalled and downloaded gain with the same result. Anybody have any ideals?
Replies (11)
Message 2 of 12
pendean
Community Legend
Community Legend
What version of autocad/lt are you using?
What is your Windows version?
Is this a sudden new problem, or is it limited to just one file, or does it happen in all files all the time and has done so for ever?
Message 3 of 12
Emmsleys
Hello @Anonymous,
A few questions for you to get a better idea of your situation.
  • Could you capture a screengrab of the error message?
  • What AutoCAD LT version are you using?
  • What is your OS?
  • Are you running it on a VM or bootcamp software?
Let me know if you have any new updates to provide regarding your thread or if you have any other questions.
Sarah Emmsley
Technical Support Specialist
Message 4 of 12
Emmsleys
I'm following up on my previous post. If you have any questions about my post let me know.
If you still need suggestions or have questions I'll be more than happy to help.
Thanks.
Please select Accept as Solution if my post or any other post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Message 5 of 12
*I have downloaded the student version of AutoCad LT 16.*
*I previously was using this version on this computer with no problem;
suddenly I cannot enter text with out the program shutting down*
*I am running Windows 8.1. I have uninstalled and reinstalled anew AutoCad
LT 16 and still have the same issue.*
*The issue occurs on file previously completed.*
*Thanks for your help!*
*Ron*
Message 6 of 12
*Ron*
Message 7 of 12
Emmsleys
Hi @Anonymous,
A few questions for you so that I can narrow down where the issue might be and to give me a better idea.
  • Have you noticed if this is happening with all files or only a specific few?
  • Are you working with a lot of customizations?
  • Have you updated any other programs on your system recently?
A few things to try:
  • Save the file locally if you save to a cloud service or a server.
  • Run AutoCAD LT in a selective startup in Windows 8, test AutoCAD LT 2016 in that environment.
  • Make sure that you have applied all updates to AutoCAD LT 2016, what build are you on?
Post back and let me know if you have any other questions.
Sarah Emmsley
Message 8 of 12
  • This issue is happening will all files. I have returned to a previous file that had no issue but, now I can't add text without a shutdown.
  • I am unaware of any customization; I'm a simple operator just learning.
  • My system uThe pdates occur automatically so, I'm not sure what's been updated.
  • All my files are saved on this laptop.
  • How do I run Autocad LT in a selective startup in Windows 8?
If I have built a drawing in 16, will an earlier Cad version open a 16 file?
Message 9 of 12
Emmsleys
Hi @Anonymous,
Okay,
First off thanks for getting back to me. Smiley Happy
Let's have you pull the following information for me.
  • I'll need a copy of a drawing file so that I can test it on my end.
  • NFO file (AKN: How to guide
You can open a 16 drawing in an older AutoCAD LT it just depends on what version it is. You can save files down in AutoCAD LT 2016.
  • Execute SAVEAS and in the save dialog window, pick an older DWG file format from the "Files of type" drop-down menu.
Let's work off of that for now and we can go back to the drawing board after taking a look at a drawing file and the NFO file.
Sarah Emmsley
Message 10 of 12
I have not been successful downloading Windows Didate but suddenly was bale to. My text issue in Autocad has gone way. Thankyou for your help and persistance.
Message 11 of 12
I have had difficulty downloading Windows Updates but, finally I succeeded
. Suddenly, my text issue in AutoCad went away. I want to think you for
your help and persistance. Goodjob.
Message 12 of 12
The same problem I'm facing right now. Cannot add text in AutoCAD. It suddenly shuts down the app. The same Windows 8.1 os I'm using.
-Pls suggest a solution for my problem
@Emmsleys wrote:
Hi @Anonymous,
Okay,
@Emmsleys wrote:
Hi @Anonymous,
Okay,
@Emmsleys wrote:
Hi @Anonymous,
Okay,
-Thanks
