- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have recently upgraded from LT 2007 to LT 2018 and created new blocks with text attributes.. When I needed to edit the text before I could just double click and a simple editor popped up [see pic1 2007] and tab to edit, it was done.
With this version I double click a block it will open the edit block definition or the enhanced attribute editor (would like to disable) [see pic1 2018].
I have searched for a solution and one I found was to hold the crtl key and click but it isn't working on new blocks. I have attached a sample file with 3 blocks that act differently and I can't make the ctrl+double click work on the new "gate label" block.
I have played around with the properties and can't make it work like the others I have included. I have gone back to 2007 and created "new gate" block that works exactly as I want to when I create new blocks with 2018.
I have also seen a post to edit the CUI but the steps aren't very clear and I am not sure that will even do what I am wanting?
@sdrisk8262 for clarity VStudley embedded your image directly in this post and edited the original subject: ENHANCED ATTRIBUTE EDITOR / EDIT BLOCK DEFINITION
