AutoCAD LT Forum
Edit a last segment in a polyline
1 REPLY 1
mary.mimnaugh
370 Views, 1 Reply
When doing a polyline shape and you entered the wrong value how can you edit that last piece without having to explode the whole object.  Now I saw if you hit control you can hightlight that last section and delete it.  But I dont think  Autocad lt 2021 has the legacycontrolpick command. Is there another system variable that controls that setting for control to operate like it does with the legacycontrolpick.  Thank you
Mary M.
1 REPLY 1
steven-g
in reply to: mary.mimnaugh
Nothing like that in LT for that you need full AutoCAD. Lt has the pedit command to make alterations to a polyline or you can use the trim command to remove a segment without exploding the whole polyline.
Forma Design Contest
Technology Administrators
