Dynamic Block Query - is there a way to create a dynamic degree bearing number that changes when rotating a dynamic block?
I know how to use the rotate parameters within a dynamic block but would love it to display the angle when using the block and of course for the number to change as the rotation angle does.
Solved by steven-g. Go to Solution.
Thanks, but I'm not sure how to automatically make the 0° increase to 45° for example upon using the block rotation parameter that was created.
As @steven-g has said you need to do a REGEN before the value in the field will change.
Howard Walker
I understand that, but how do you create the field that I 'would' need to Regen
It is easiest inside the block editor. Add an attribute to the block and when you get to the 'attribute default' there is the option to insert a field
In the field dialogue select block placeholder and then select the rotation parameter, click OK and exit the block editor. Run attsync choosing the block, and then change the rotation and run regen.
Brilliant solution thanks!
SORTED, TYPE: "ANGDIR" -> How do you get around the issue with it displaying the angle as 270° when it is in fact 90°?
