DWG file is write protected???
Message 1 of 16
Everytime I try to save one of my files it says i cannot as the DWG FILE IS WRITE PROTECTED. I know i'm a novice and don't use CAD much, but i have never done this to any of my files, So how can a take of the write protection?
Klaus
Accepted solutions (3)
Replies (15)
Message 2 of 16
Either save them using a different name, or using Windows Explorer, right-click on the file(s), select Properties, then on the General tab, uncheck Read-only. -- Daniel J. Altamura, R.A. Altamura Architectural Consulting and SoftWorx, Autodesk Authorized Developer -------------------------------------------------------------------- "kconst" wrote in message news:[email protected]... > Everytime I try to save one of my files it says i cannot as the DWG FILE > IS WRITE PROTECTED. I know i'm a novice and don't use CAD much, but i > have never done this to any of my files, So how can a take of the write > protection? > > Thanks, > > Klaus
Message 3 of 16
I guess you mean the File(s) in the autocad screen and then DWG Properties, did this, but read only was not checked. thanks for the help anyway
Message 4 of 16
Is it just one of your files or any one of your files. The solution will be different depending.
The first response should work if it is only one file. If it is any file, then you may have a problem with the destination folder/drive being read only.
I am not an expert here, but hope this helps.
jeff <><
Message 5 of 16
To add to Jeff's post, if your destination is like a re-writable CD for example you will always have this problem: anything on a CD is automatically set to read only and AutoCAD won't over-write such a file. If you are saving to a server folder, make sure you have write-access to that folder, and most importantly, make sure your network card on your PC did not time-out and lose the connection to the folder too (AutoCAD sees that as write-protection as well). -- Dean Saadallah Add-on products for LT http://www.pendean.com/lt --
Message 6 of 16
No. As I described in my first post, you need to use Windows Explorer, not AutoCAD. Again, using Windows Explorer, select the file(s), right-click, select Properties, then on the General tab, uncheck Read-only. -- Daniel J. Altamura, R.A. Altamura Architectural Consulting and SoftWorx, Autodesk Authorized Developer -------------------------------------------------------------------- "kconst" wrote in message news:[email protected]... >I guess you mean the File(s) in the autocad screen and then DWG Properties, >did this, but read only was not checked. thanks for the help anyway
Message 7 of 16
That does not work (using Windows Explorer) because the Read only box is not checked, so can't uncheck it.  I think this is about AutoCad lock files being screwed up and not about file permissions.
Message 8 of 16
pendean
Community Legend
Community Legend
AutoCAD only responds to your OS (local or server) locking files, either because of a log-in rights restriction or an in-use file that is in place, not much else. The read-only box is often not enough to check for a problem like this.
Since you are answering a ten-year-old post, care to share with us what is your setup and where your files are located, your OS, AutoCAD version, and if this is a unique problem to certain files or all files? And is this a new problem?
Or are you really stuck in the year 2005 and reaching forward in time for help?
Message 9 of 16
Hi
Thanks for the reply. I wasn't sure if I'd get a reply since this thread is so old. However, it seems that the problem still occurs.
I am using Civil 3D 2013 Infrastructure Design Suite Premium 2013
HP EliteBook 8570w, 16 Gb RAM, 64 bit, i7-3820QM CPU @ 2.70 GHz
Windows 7 Enterprise, 6.1.7601, Service Pack 1 Build 7601
My AutoCAD program files are on a local drive while my drawing and other files (templates, fonts, etc.) are on a network drive with Windows Server OS (not sure what version)).
When I try to delete the dwl and dwl2 files, I get the following message, even though the file is not in use by another program:
[cid:[email protected]]
This is the first time this has happened to me after using AutoCAD for hundreds of hours. This isn't a critical problem since I can just save the file with a different name, but it is still quite annoying to have to use such a workaround.
Doug
Doug Edwards MBA, P.Eng.
Senior Restoration Engineer | Ing?nieur principal de restauration
Ecosystem Management Branch | Direction de la gestion des ?cosyst?mes
Fisheries and Oceans Canada | P?ches et Oc?ans Canada
985 McGill Place | 985, place McGill
Kamloops BC V2C 6X6 | Kamloops (C.-B.) V2C 6X6
CANADA | CANADA
Telephone: (250) 318-5711 | T?l?phone: (250) 318-5711
Facsimile: (250) 851-4951 | T?l?copieur: (250) 851-4951
Hi doug.edwards,
pendean (Consultant) posted a new comment in AutoCAD LT General Discussion on 10-12-2015 07:13 AM :
________________________________
Re: DWG file is write protected???
Reply | Give Kudos
Autodesk Community sent this message to [email protected].
You are receiving this email because a new message matches your subscription to a topic.
To control which emails we send you please go to, manage your subscription & notification settings or unsubscribe.
Message 10 of 16
pendean
Community Legend
Community Legend
Please confirm where locally do you store your files: we all use Win7 and have done for as long as it's been around and AutoCAD 2013-14-15-16 does not lock anyone out here yet.
DWL and DWL2 files are not locking mechanisms, they are there for WHOHAS command inside AutoCAD only. Like I said, your Server or your OS is locking up your files or those folders.
Message 11 of 16
I think you have the drawing open as read only. If not you can do save as to a different location of the existing one
Message 12 of 16
Hello, bro
I am answering the 12 years old post. I solve this problem by Save As menu. I save the file in another distinction and delete the original file and then I move this file to my desired location.
This is sample and easy to solve.
I am very happy to reply your two years last post 🙂
Message 13 of 16
Type save in command line. in the pop-up window. Change the name of your drawing. This works in 2000i. I haven't tried it in a newer release
Message 14 of 16
yehyaa14
Community Visitor
Community Visitor
Try save as under a different name. Then delete original file and rename your saved as file as per original one.
Message 15 of 16
RobDraw
This was solved in 2005.
Rob
Message 16 of 16
jjustice
Community Visitor
Community Visitor
I have the same problem now that I'm working on a new laptop. My software is ACAD 2020 and the files I create on this new laptop all said "write protected". I changed the "open file with" from AutoCAD Application to AutoCAD DWG Launcher and that seems to have fixed the "write protected" issue
