Running AutoCAD 2023 in Windows 11
When using PUBLISH to create a partial group of pdf layouts, I find that one or more layouts will be indiscriminately dropped from the created list.
I enter paper space in a layout, start PUBLISH, select the layouts to remove, select publish, create a file name, normally I do not save the selected list, then continue.
The layouts are processed into a pdf file, but when I check the file, one or more of the layouts have been eliminated from the group. Upon repeating the process, I find that quite often a different layout has been eliminated from the group.
The drawing is saved every time before I attempt to publish. I have checked and double checked my plot config on each layout. If I publish all layouts at once, this does not occur.
I never had this issue when using Windows 10.
Anyone else experiencing this problem? Were you able to solve it? I am close to re-installing AutoCAD, but was trying to avoid that.
Any help would be appreciated.
Solved by d_badger. Go to Solution.
