I successfully downloaded AutoCAD LT 2016. The problem I'm having is I pull up existing DWG files and the drawings have random lines from the drawing pulled out in random directions. How can I fix this? Is it a graphics view adjustment?
Solved by pendean. Go to Solution.
Type in the command GRAPHICSCONFIG and turn off hardware acceleration and see if that helps.
Turn off your hardware accelerator. click OK. and then repeat by turning it back on. This typically doesn't happen on 2021 but for some reason that fixed the problem immediately.
