Displaying area in Square Meters in AutoCAD LT
autocad1878
Message 1 of 12
autocad1878
Good morning,
I have an drawing and need to know the area, I can use the measurement tool to get a figure, but I can't use that figure to work out the area??
Can you help ?
@autocad1878
john.vellek has edited your subject line for clarity: Area
Replies (11)
Message 2 of 12
h_s_walker
If you're talking about the blue dashed line area is one of the items listed in PROPERTIES (Ctrl+1) or Right Click and choose PROPERTIES
Howard Walker
Left Handed and Proud
Message 3 of 12
autocad1878
Sorry I'm trying to work out meter squared area?
Message 4 of 12
h_s_walker
See the attached video showing how to use the calculator in the properties to find the area you require
Howard Walker
Message 5 of 12
john.vellek
Hi @autocad1878,
Have you figured out how to calculate the  area in AutoCAD LT? It looks like @h_s_walker has given you some great help.
If you have a closed polyline you can simply select it and it will show the area in the Properties palette. If you have a bunch of lines you can edit them using PEDIT to make them a closed polyline or you can also use BO (Boundary) to drop in a polyline.
If the display of the area is in MM and you want Meters, an easy way to get this to display is with a Field.
I made a quick video of that process for you.
I hope this helps.
John Vellek
Message 6 of 12
autocad1878
Sorry, I'm not always online. Fantastic guys thank you so much for your help.
Both Videos helped me achieve what I needed.
Message 7 of 12
How is it possible to do this in Auto Cad 2014 LT?
I want my area to be viewed in square meter units instead of long millimetre number!
Thank you!
Message 8 of 12
steven-g
Have you watched the two screencast's? Both these methods will work in AutoCAD LT 2014
Message 9 of 12
MajaMaliszewska
Community Visitor
Community Visitor
This gave me the wrong result. I had to type in 0.000001 to convert sq mm to sq m?
Message 10 of 12
MajaMaliszewska
Community Visitor
Community Visitor
Also, how do you use it as a permanent solution, instead of typing in every time, you would have an option to display the area in meters?
Message 11 of 12
h_s_walker
@MajaMaliszewska No there is no permanent solution.
Howard Walker
Message 12 of 12
vladimirvay
Thank you very much!
