Dimensions not visible in layout view
BillW435
Message 1 of 50
BillW435
This is one of those on-again off-again frustrating issues.
The problem: I add a dimension in Model Space, but it is not visible in Layout. No problem with drawing items, only dimensions. After some "floundering" (not an official AutoDesk term),  I see the dimension in Layout. Don't know what I'm doing wrong, or how I manage to get the dimensions to show again. Any and all help appreciated.
Yes, have searched the help file and manuals to no avail.
Bill
LT 2011
Windows XP
Accepted solutions (4)
Replies (49)
Message 41 of 50
I'm glad to have been of assistance.
Enjoy your weekend.
Message 42 of 50
m-salahudheen
Community Visitor
Community Visitor
My problem resolved, Thank you for the valuable information
Message 43 of 50
AISHWARYANIDHALKAR95
Community Visitor
Community Visitor
thanks a lot.....
Message 44 of 50
Sumith_PERERA
Observer
Observer
Thanks for your solution, it worked for me
Message 45 of 50
Jrhannahwcu42
why does this get turned off? i had this same issue in 25 but my other viewports still had dimension same layer and style.
Message 46 of 50
CGBenner
@Jrhannahwcu42
Hello, can you describe in more detail what you are experiencing?  This is a very old post and your situation may not be exactly the same.  Have you tried any of the solutions mentioned in this thread?  Thanks!
Chris Benner
Message 47 of 50
Jrhannahwcu42
Sorry I did get it fixed with the annoallvis command but im curious as to why that value was switch and as to why it was only affecting certian viewports and not all of them. the dimensions we all on the same layer and type. and all the viewports were copies from previous ones just moved to where i needed them.
Message 48 of 50
cadffm
all the answers are in the key to learn about the annotation feature.
Some objects has the property "annotation"
Such objects are scaled or hide, depending on what scales are supported/added to the objects.
And
in model, cannoscale Setting
in layouts, viewport-property annotation scale
Annoallvisible, what is stored per layout, display all annotation objects, also if they don't support the current annotation scale.
Too much for a short forum post.
Start with youtube: Autocad annotation
Check out the properties Annotation and Annotation scales [...]
Sebastian
Message 49 of 50
cadffm
>" but im curious as to why that value was switch"
Accidently pressed the AnnoAllVisible button in your statusbar?
The only way I now.
>"and as to why it was only affecting certian viewports and not all of them"
AnnoAllVisible affecting all viewports.
Off(0) - Viewport displaying annotation only if they support the viewport annotation scale.
On(1) - All annotation objects are displaying, in all viewport of this layout.
HTH
Sebastian
Message 50 of 50
sreid0077
New Member
New Member
Thank you, sir 14 years later, and this is still true
