Dimensions not visible in layout view
BillW435
Message 1 of 49
BillW435
This is one of those on-again off-again frustrating issues.
The problem: I add a dimension in Model Space, but it is not visible in Layout. No problem with drawing items, only dimensions. After some "floundering" (not an official AutoDesk term),  I see the dimension in Layout. Don't know what I'm doing wrong, or how I manage to get the dimensions to show again. Any and all help appreciated.
Yes, have searched the help file and manuals to no avail.
Bill
LT 2011
Windows XP
Accepted solutions (3)
Replies (48)
Message 21 of 49
ScottHodges
When you check the properties of your viewport, it should indicate the annotative scale. If you have used annotative objects, only those for the selected viewport annotative scale will be visible in the viewport. Annoallvisible turns the annotative objects on for all annotative scales, then you can check which one you need on. Usually one of the main reasons many of us avoid annotative objects: more trouble than they are worth, considering most of us survived for 30 years using autocad without a need for them.
Message 22 of 49
michaeld
You have your dims layer frozen in your viewport. Simply unthaw and it works.
Message 23 of 49
Thank you so much for posting this!
Message 24 of 49
You Got it! If you're having problems with notes not showing up when
printing let me know
Message 25 of 49
BillW435
Not sure I should be getting thanks for this, but you are welcome.
Bill
Message 26 of 49
I just found your suggestion and it fixed my issue straight away.
Thanks!
Message 27 of 49
Great, let me know if you need anything else.
Message 28 of 49
Turning on the "Show Annotation Objects" button worked! Thanks.
Message 29 of 49
shanik329
help! i have tried all those suggestions. i unfroze all my layers in VP.  my annotative scale is 1:1.
the only idea i have is that my dimstyle is not the same in model and layout. how can i change that. when i plot, i dont see my dimensions in layout or preview. i am just fiddling here with all the butttons.
Message 30 of 49
cadffm
LAYER and AnnoScale, that's all.
Upload your File and we can help, without the file: Start re-reading the post again (sorry).
If you can see the dimension in the tab you want to plot:
Check the PLOT property of you Layer(s).
Where are you? MODEL tab or LAYOUT tab?
Where is youre DimensionObject? MODEL tab or LAYOUT tab?
If in MODEL tab: Can you see the dimension in MODEL tab?
Wnat to plot a Layout?
Can you see the modelspace dimension in your Layout tab?
(Share your DWG for quicker solutions)
Sebastian
Message 31 of 49
pendean
Community Legend
Community Legend
Post your actual DWG file, let's have a look for ourselves.
Message 32 of 49
shanik329
here it is !
if anyone can tell me what is hindering the dimensions from being visible in layout
thanks
Message 33 of 49
cadffm
Your Layer (ID-DIM) is frozen in this Viewport, nothing more.
Go into this vieport (doubleclick in the area inside the viewport),
check your Layermanager palette. Column "VP Freeze" (not just "Freeze").
You will see there are THREE Layers freezed for this layout viewport, not just the ID-DIM.
This is a setting of the current viewport, so you can see this column only if you are not on Model TAB.
Learn also how to use the VPLAYER command.
Sebastian
Message 34 of 49
shanik329
thank you !
i thought i unfroze all the layers in model and layout. now i see i have to look  that VP freeze column.
it was driving me nuts!
thank you again
Message 35 of 49
jrcbadger
Thank you Katani. I had the same problem and your ANNOALLVISIBLE, 1, solution worked.
What did I do wrong to get this problem?
Thanks again,
Jeff
Message 36 of 49
cadffm
If you want to work with annotation feature:
-Your mistake is to forget to add the anno scale (you using in your viewport)
  OBJECTSCALE [F1]
  https://help.autodesk.com/view/ACD/2021/ENU/?guid=GUID-85450EAE-8B5B-47BD-AA45-3DB5B733FD64
OR
- your Annotation scale in your viewport is wrong (your objects doesn't support this anno scale / Objectscale)
Select your viewport, check the anno scale setting.
If you dont want to work with annotation feature
- Your mistake was to set objects to annotation YES.
Perhaps also your dimscale
DIMSTYLE
Sebastian
Message 37 of 49
I have been having this same problem and this fixed it! Thank you!
Message 38 of 49
BillW435
Not sure I helped, but glad you resolved the issue. I remember struggling with this problem!
Bill
Message 39 of 49
keltonB67J3
Observer
Observer
This was my problem. Thanks!!
Message 40 of 49
lborrayez0001
Community Visitor
Community Visitor
you were really helpful.
