Dimension Variable question
mondes
Message 1 of 14
mondes
I'm curious to know if it's possible to control variables for the dimension continue command.  I use this quite a bit but I've noticed that the variable for Fit, text movement is set for "move text, add leader".  I would like it to default to "keep dim line with text".  Is it possible to change this default globally?  If so, I would make this change in my dwt. file.
Replies (13)
Message 2 of 14
h_s_walker
Check your dimension style. Dim Continue always follows what settings you have in your dim style.
Howard Walker
Left Handed and Proud
Message 3 of 14
Emmsleys
Hi @ mondes,
Check out this AKN Article to see if it helps with your question. Please let me know if it doesn't and I will hunt down some more resources for you.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
Sarah Emmsley
Technical Support Specialist
Message 4 of 14
mondes
There doesn't appear to be a setting for "Dim Continue" in the dimstyle dialog box under the "fit" tab or anywhere else.
Message 5 of 14
mondes
no, I'm not seeing anything.  there is a command called "dimcontmode", but it doesn't have a setting for fit.
Message 6 of 14
pendean
Community Legend
Community Legend
DIMSTYLE command is where you set the "fit" that you desire: this would apply to ALL the dimensions you crate with that one dimstyle.
what LT version are you using? And what is DOMCONTINUEMODE set to exactly? If you looked it up in help, it may be using a wrong setting inherited from the dim you started with? The statement made earlier about dimcontinue following the dimstyle can be overridden.
Message 7 of 14
mondes
If I do a dim linear and base a dim continue off it, then select the 1st one: in properties, Fit, text movement shows "Keep dimension line with text";
then, select the continued dimension: in properties, fit, text movement shows "move text, add leader".
I see no such variable for any dimension in the dimstyle dialog box.
LT 2017
Message 8 of 14
mondes
also, curiously, the system variable, dimtmove, has three settings.  the default is 0 (moves dim line w/dim txt).  so, the question is, why does the system variable change to 1 (ad a leader when dim txt is moved) for the continued dimension?
Message 9 of 14
DIMTIX is the variable, turn it on. Defaults to off.
Thank you for asking! That has bothered me enough to not use dimcontinue, but I've always just clicked my way around that one. Hopefully this doesn't break something else we like.
Message 10 of 14
pendean
Community Legend
Community Legend
If you looked it up in help, it may be using a wrong setting inherited from the dim you started with.
If you have no idea what anyone here is writing to help, post your DWG file and point to the DIM you are wishing to "continue' from and we can all decipher the real problem for ourselves.
Message 11 of 14
mondes
Um, sorry, but no.  DIMTIX is already set to "on".  still does it.
Message 12 of 14
mondes
Not sure how to post a dwg. file.
Message 13 of 14
pendean
Community Legend
Community Legend
Come to the website, to this thread, click the blue REPLY button under my post, you'll get to a second screen where you can type words and below it a link to attach files.
Message 14 of 14
Emmsleys
Following up with your thread, it's been a few days since I posted back. If you are still having an issue adding a drawing file to the thread try logging in directly to the forums site.
Sarah Emmsley
