Dimension Text Size
Dimension Text Size
Dimension Text Size
I have AutoCAD LT 2017 and in the past, I could always change the size of my Dimension Text by changing the Text Height.  I'm in a drawing now where I change the Text Height in Properties but the size of the dimensions do not change at all.  Is there another setting I need to change to make this work?  Thanks,
Mike
pendean
Community Legend
Community Legend
Depends if that is how your DIMSTYLE is set up or not: start DIMSTYLE command up, open your active dimstyle and compare this file's settings with another that worked the way you want.
Hint
Thank you, that helped me find the problem!
Mike St Jean • Process Engineer
RSCC Wire and Cable LLC – Exane Products
A Marmon Wire & Cable/Berkshire Hathaway Company
Office: (860) 653-8486 • Fax: (860) 653-8395 • Cell: (860) 653-8486
Email: mike.stjean@r-scc.com
Web: www.r-scc.com
[cid:image003.jpg@01CF7F3B.B1B6A9D0] [Exane Logo 2]
RSCC Wire & Cable LLC is a world leader in the design & manufacture of insulated high performance Control, Power, Instrumentation and Specialty electrical cables. For over 95 years we have been committed to meeting the most demanding customer requirements through innovative design, manufacturing excellence and unequaled customer service.
CONFIDENTIALITY NOTICE: This email and any attachments are confidential and may be protected by legal privilege or otherwise. If you have received this e-mail in error, please do not read, copy, or distribute this e-mail or any attachments, and please notify us immediately by returning it to the sender and delete this copy from your system. Thank you.
Hi mike.stjean,
pendean (Consultant) posted a new reply in AutoCAD LT Forum on 09-23-2016 05:43 AM :
________________________________
Re: Dimension Text Size
Hint
Reply | Accept as Solution | Give Kudos
Thanks for being a Autodesk Community member.
Your Autodesk Community Team
You're receiving this because you registered for the Autodesk Community.
Manage your notification settings or unsubscribe
Select a different language for these emails.
To get the most out of your product, visit the Autodesk Knowledge Network.
Privacy | Legal Notices & Trademarks| © Copyright 2016 Autodesk Inc. All rights reserved
Emmsleys
If you have any additional questions post back in the thread.
Please select Accept as Solution if any post in this thread resolves your issue, or reply with additional information if the problem persists.
Sarah Emmsley
Technical Support Specialist
claired
I'm finding that I am not given the option to adjust the dimension text height at all...In Properties or Dimension Style Manager. Any ideas?
cadffm
Hi
I guess you set a fix text hight in your textSTYLE, start command STYLE and check
the height of style standard.
Not asked, but my basic rules for you:
It's not good to use predefined styles of any kind.
Use your own definitions with another name!
In this case here, do not use style standard, not for text, not for dimstyles.
Create your own and choose a well name.
Beware of trouble with import/export content from or to other files from extern.
Sebastian
pendean
Community Legend
Community Legend
@claired STYLE command settings override all other locations if you all do it old-school style over there.
