Thank you, that helped me find the problem!
Mike St Jean • Process Engineer
RSCC Wire and Cable LLC – Exane Products
A Marmon Wire & Cable/Berkshire Hathaway Company
Office: (860) 653-8486 • Fax: (860) 653-8395 • Cell: (860) 653-8486
Email:
[email protected]Web:
www.r-scc.com[cid:
[email protected]] [Exane Logo 2]
RSCC Wire & Cable LLC is a world leader in the design & manufacture of insulated high performance Control, Power, Instrumentation and Specialty electrical cables. For over 95 years we have been committed to meeting the most demanding customer requirements through innovative design, manufacturing excellence and unequaled customer service.
CONFIDENTIALITY NOTICE: This email and any attachments are confidential and may be protected by legal privilege or otherwise. If you have received this e-mail in error, please do not read, copy, or distribute this e-mail or any attachments, and please notify us immediately by returning it to the sender and delete this copy from your system. Thank you.
Hi mike.stjean,
pendean (Consultant) posted a new reply in AutoCAD LT Forum on 09-23-2016 05:43 AM :
________________________________
Re: Dimension Text Size
Depends if that is how your DIMSTYLE is set up or not: start DIMSTYLE command up, open your active dimstyle and compare this file's settings with another that worked the way you want.
Hint
Reply | Accept as Solution | Give Kudos
Thanks for being a Autodesk Community member.
Your Autodesk Community Team
You're receiving this because you registered for the Autodesk Community.
Manage your notification settings or unsubscribe
Select a different language for these emails.
To get the most out of your product, visit the Autodesk Knowledge Network.
Privacy | Legal Notices & Trademarks| © Copyright 2016 Autodesk Inc. All rights reserved
