Im trying to make a costum macro of a linear dimension.
So when i click my costum macro in my toolbaar i'd like to set a linear dimension with a costum dimstyle and costum layer.
I tried several thinks but nothing seems to work so far.
This is what i got for example..
^C^C-layer;_s;"CostumLayer1";;-dimstyle;r;;"CostumDimStyle1";;_dimlinear;
Anyone that can help me solve this?
Thank you
Solved by sthompson1021. Go to Solution.
Using autocad 2016LT.
this are 3 buttons for example.
The black dimension is standard, standard layer and standard dimensionstyle in millimetres for example.
The Red one is for electric, and should be under the layer Electric and should have a different dimension style in centimetres
The blue one is for water, and should be under the layer Water and should have a different dimension style in centimetres
And because i wouldn't need to change my layer and dimensionstyle all the time id like to use macro's...
Thanks in advance
This works for me in 2016 full autocad
^C^C-LA;S;YOURLAYER;^C-DIMSTYLE;R;YOURDIMSTYLE;DIMLINEAR;
