I'we updated from AutoCad LT 2018 to AutoCad LT 2021 and the colors are different. Even window transparency is different.
Is there in Autocad some option to modify the programs color or is it from windows?
the color is now way to dark and needs to be changed
I use dark theme with all colors restored to classic in both LT versions
Than
Solved by vinodkl. Go to Solution.
Sorry, you cannot change the color. The dark blue interface was started with the 2020 version it remains the same on 2021 well and it was designed to work with recent contrast improvements and sharper icons. And you cannot change that🙂
You can log feedback so that it can be implemented in the future. Below is the link for the feedback page:
