AutoCAD LT Forum
Delete Layout tabs with a script
1 REPLY 1
weslie_howard
666 Views, 1 Reply
Gang I have several hundred wiring diagrams that need to be imported into another program so we can generate CGM files. The problem I am having is I have a macro written for the other program to open the DWG and then export to a CGM file. The problem is that the other program is opening the layout tab instead of the model tab. So what I would like to do is create a script file that I can run in AutoCAD LT to delete the current layout tabs. I was also hoping I could run this as a batch process I really do not want to have to open each one one of these files separately.
Any insight or help anyone can offer would be greatly appreciated.
Keith Howard
Tags (1)
1 REPLY 1
pendean
in reply to: weslie_howard
Look up TILEMODE or MSPACE commands in HELP and just add one of them to your script.
Forma Design Contest
Technology Administrators
