AutoCAD LT Forum
Default hatch patterns.
2 REPLIES 2
mark.grossesteel
293 Views, 2 Replies
The default hatch patterns are not getting loaded at autocad startup. The gradient options are the only thing that shows up in the hatch pattern dialog box. Any idea why? Is there some default setting that is turned off, or a hatch setting value that needs to be changed?
2 REPLIES 2
pendean
in reply to: mark.grossesteel
May I ask you to provide a screenshot(s) of "where" you are looking for these "defaults" that you cannot find?
There is no OFF-the-defaults button, but there are lots of choices you need to make to find what you want.
On command line type following and it’ll show you where AutoCADs built in hatch pattern definitions are saved
(findfile"acadlt.pat")
(findfile"acadltiso.pat")
Paul Li
IT Specialist
@The Office
Forma Design Contest
Technology Administrators
