AutoCAD LT Forum
cursor snapping to grid lines only when drawing in dyn mode
7 REPLIES 7
Message 1 of 8
1297 Views, 7 Replies
like the title says....i have snap and grid turned off i have made sure. it happens in every drawing i open. only when i have dyn clicked does his happen. i can draw all i want without the cursor jumping around or anything but when i want to do anything with dyn clicked it jumps to a random grid pattern. anyone have any info?
all the other times ive seen this problem addressed it doesnt have anything to do with specifically drawing wiht dyn clicked...
7 REPLIES 7
Message 2 of 8
rkmcswain
What do you mean by "dyn clicked"?
Do you mean DYNMODE set to a positive number?
And you are sure that SNAPMODE = 0 and SNAPGRIDLEGACY = 0
Message 3 of 8
in reply to: rkmcswain
sorry, i mean the dynamic input button to the right of otrack, the one that lets you manually put in the length of a line or size of a rectangle....
Message 4 of 8
you know what its acutally snapping to a grid for everything im doing, not just when dyn input is selected.....and yes i have made sure the grid and snap are turned off
Message 5 of 8
pendean
LT version is....?
Windows version is....?
Is this a sudden problem that just appeared in ALL files?
Or is it limited to this one file?
Explain the background behind this problem please.
Message 6 of 8
in reply to: pendean
autocad 07
windows xp (holy crap i know)
happens in all drawings
started about 4 days ago,i  thought it was just going slow so i restarted my computer only to find that it wasnt just going slow, but doing the whole random grid snapping thing.
Message 7 of 8
rkmcswain
First off, GRIDMODE has nothing to do with SNAP so don't worry about that.
Please post a Screencast illustrating the problem. Set GRIDMODE=0 and DYNMODE=0, and show us the smooth cursor. Then set DYNMODE=3 and show us how the cursor is acting like SNAPMODE=1 then.
Ref: https://knowledge.autodesk.com/search-result/caas/simplecontent/content/download-autodesk-screencast...
Message 8 of 8
Emmsleys
Following up on your thread, were you able to find a solution or a workaround? Did any of the posts in the thread help with the issue?
Please use the Accept as Solution for those post’s that helped. It may benefit other users who might have a similar question or issue.
Thanks for your time.
Sarah Emmsley
Technical Support Specialist
”Boost
