I use Autocad primarily for nesting and one of the things that I really rely on is using ctrl-c/x, ctrl-v (paste) to quickly nest pieces on a flat representation.
I recently upgraded to 2019, but the base point in 2019 on selected shapes has changed from the bottom left "extent" of the lines themselves, to the bottom left extent of the "hidden geometry" of the piece. It is only a problem with shapes that contain arcs. I have included an irregular piece with an arc as an example. The second example has the same shape but with the arc extended as a circle to represent the "hidden geometry". (hopefully, this all makes sense).
I really want to keep using ctrl c, ctrl v as the 2012 behavior is coincidentally very useful for my nesting requirements.
Thanks!2012 example
2019 example
