Create a block using script with uniform scale
cadcammike
cadcammike
I have created an excel file that generates hundreds of internal blocks in a Autocad 2022 Lt drawing, but when i try to insert them they are not uniformly scaled. Is there a way to create a uniform scale block in a script. Or even a way to change the block property to uniform scale from the command line?
steven-g
Creating uniformed scale blocks does look to only be an option in the block dialogue or block editor (so not available from the command line). This post looks to have a solution by making an edit in the registry but playing in the registry is only for the brave.
But what is causing your script to create non-uniform blocks in the first place? Your script should have total control of what it is creating. Can you post a copy of the script and a dwg showing clearly what the problem is.
cadcammike
Thanks for the reply. I did see the regedit option but didn't think that it would control the script.  I have 5000 blocks that i created with the dialogue box. But made another one thousand with a script. These were non uniform. The solution that worked for inserting all 6000 blocks with a script was to insert the block name then specify the scale then the insertion. I rewrote the vba in excel to pull the value for the scale before the insertion point. The output is shown below
Old script where scale is 1 and insertion is origin
-insert;ABC.dwg;0,0;1;;;
New script
-insert;ABC.dwg;scale;1;0,0;;
Consider this resolved.
Credit to MVG1 post 05-13-2020 in reply to CADffm.
