- Mute
- Permalink
- Report
I'm using AutoCAD LT 2020 on Windows 10. I have some building drawings that I am trying to calculate the area of the rooms. Sometimes, when I click a corner of the room, it won't 'stick.' For instance, a conventional room has 4 corners, I would click each corner and then AutoCAD would calculate the area of that rectangle (using the Measure command). Sometimes, I click a corner and it's like I never clicked it at all. Sometimes I can click several times and it finally will stick, but not always. I seem to only have this problem with one of our campus buildings, which is a newer building and not drawn by the same architect or person. I suspect it's some setting that is different but I can't figure it out. I tried changing the Object Snap settings to be the same as other buildings, but to no avail. Thank you for your help.
