Binding xrefs
Binding xrefs
ralindberg5Y8L8
Observer Observer
Message 1 of 13
Binding xrefs
ralindberg5Y8L8
Observer
Observer
Using Autocad LT 2021, in order to bind an xref to the current drawing, I see the help file instructions tell us to open the External References palette, select the reference name you want to bind, right-click, and then click Bind.  I do that.  Except after right clicking, the dialog box that appears does not have the Bind choice as one of the options. What am I missing?
Replies (12)
Message 2 of 13
Usually when I bind an xref, I select the xref and select bind. The options I get are bind or insert. I have always used in insert option.
Message 3 of 13
pendean
Community Legend
Community Legend
So what does the pop-up look like? We can't see your screen, post a screenshot please.
Message 4 of 13
ralindberg5Y8L8
Observer
Observer
Attached image is where I thought I should find a "Bind" option.
Message 5 of 13
You can not bind a pdf
Message 6 of 13
vinodkl
You cannot bind the PDF as we bind the drawing. Instead you could import the pdf as objects. To do that click on the xrefed PDF and you would see an option to import PDF as an object in the ribbon as seen in the snapshot below. Now click on that and press enter, and then you would be prompted whether you want to keep the xref, detach or unload. Select unload since we no longer need the xrefed PDF.
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 7 of 13
peta.o
I'm frustrated with this too.
I need to insert an xref, but need to bind it, but there is no option. I would like some helpful solutions too. 😞
Message 8 of 13
RobDraw
Do you mean that you want an answer other than a PDF cannot be bound to a .dwg?
Rob
Message 9 of 13
h_s_walker
Why do you need to bind it? Are you sending the drawing out to someone? If so why not use etransmit, it creates a zip file which contains all items needed to open the drawing.
Just tell whoever to put all the files in the same directory.
Howard Walker
Left Handed and Proud
Message 10 of 13
Data integrity is a vital part of the surveying industry and minimising risk of losing content is highly important.  You cannot rely on the receiving party to follow such instructions or continue to pass the drawing on fully intact.  This is why the ability to maintain a drawing file without any xrefs is critical.  When complying with Government contracts this is also a factor and often required particularly because archiving processes in Government agencies may file name or metadata information contrary to the correct operating requirements of the drawing.
Relying on humans to do the right thing is not reliable...
Message 11 of 13
pendean
Community Legend
Community Legend
I suspect you and a few others are off-topic from the original post from 2-months ago where the fella posting decided to go home and the me-too fella from yesterday did not do a good job of explaining the situation either.
Lets see what these two fellas come back to state is the actual problem is, if they ever do.
TIA
Message 12 of 13
I can help you with a .JPG.
Open the .JPG in mspaint editor.
Ctrl+A to select all.
Ctrl+C to copy to clipboard.
Go back to ACAD, and Ctrl+V to paste it in.
Message 13 of 13
I wasn't aware of the etransmit feature until I read your post. You have just saved me a great deal of time. Thank you!
