AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
COPYING A BLOCK MODIFIED IN ANOTHER DRAWING BACK INTO THE ORIGINAL DRAWING AND UPDATING THE BLOCK IN THE ORIGINAL DRAWING
2 REPLIES 2
mr_staay
202 Views, 2 Replies
 WHEN I MODIFY A BLOCK IN A COPY OF A DRAWING, HOW CAN I MAKE SURE THAT THE BLOCK IN THE ORIGINAL DRAWING WILL BE UPDATED AS PER THE MODIFIED BLOCK ?
2 REPLIES 2
paullimapa
in reply to: mr_staay
pendean
BLOCKs do not work like that (changes you make in your open dwg file somehow update the block in the source file): looks like you are ready to move to using XREFs if this is a dire project need.
You can recopy back to the source as explained above as a workaround if fixing it at the source first is not an option.
A simpler fix: RENAME the block you no longer want to something else (like MYBLOCK-OLDNAME), then just INSERT the new look old name block into that file.
Technology Administrators
