I haven't been able to find any solutions as to why today the move and copy to a distance fails to work. I select copy to 60cm for example, and no line copies or appears. Same with move function. I am still able to copy or move by dragging it to no specific distance. This is happening in all of my files. Please help!
Solved by cadffm. Go to Solution.
Solved by pendean. Go to Solution.
Thanks for trying, I just started a new thread at least I see where they're going now.
😅 I am out OF IDEAS, not out of this thread 👍
Reset (use the Export option), and we will see
Sebastian
I really didn't want to do that so I tried to restart AGAIN (for the 3rd time) and for some reason everything works. I don't understand but thank you.
How to open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
