AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
AutoCAD 2023LT 3D
2 REPLIES 2
kimsmaile
135 Views, 2 Replies
AutoCAD 2023LT 3D
The moderators have translated this post from Korean to English.
Hello? The 2023LT version is in use by your company.
In the previous version, switching was free to use mouse wheel + shift, but before 2023LT, we found that the transition screen did not work because it left early and the option was late.
1. Will the 2023 LT version be able to switch screens in that way?
For .3D 2 related matters, you can use EXTRUDE in previous versions.
-Has 3D changed in the > 2023LT version?
안녕하세요? 2023LT 버전을 회사에서 사용 중입니다.
이전에 버전의 경우 마우스 휠 + 시프트 활용하면 전환이 자유로웠지만, 2023LT 이전에는 일찍 일찍 퇴장하고 옵션이 늦어서 전환 화면이 되지 않는 것을 확인했습니다.
1. 2023년 LT버전이 그런 방식으로 화면 전환이 가능할까요?
2. 3D 관련 사항의 경우 이전 버전에서 EXTRUDE를 사용할 수 있습니다.
 -> 2023LT 버전에서는 3D가 달라졌나요?
2 REPLIES 2
RobDraw
in reply to: kimsmaile
No 3D in LT. Does that answer your question?
Rob
pendean
"If you want to model in 3D, you have to use the full version of AutoCAD. In AutoCAD LT, you can open and view 3D models created in the full version of AutoCAD, though you can’t create new ones or edit them, other than to move, copy, or delete them.
AutoCAD LT is a 2D drafting program, it doesn’t have much visualization or presentation capabilities. Whereas you can create and edit 3D models with solids, surfaces, and mesh objects on the full version of AutoCAD but not on LT. "
Read more online if you want https://www.google.com/search?q=3d+in+autocad+lt
Forma Design Contest
Technology Administrators
