I have a project with 3 almost identical floor plans. To simplify the process, I detailed one file, now I want to make exact same changes on other ones. Changes include layer appearance (a lot of changes in lineweight, linetype and true color layers). Can I copy all layer properties (lineweight, colors etc) to others at the same time ? Going one by one would be too time consuming. In the past I would copy the first file, delete everything and paste what I need to the same coordinates, but there are a lot of small changes and I don't want to miss any. Is there a better solution? I've seen post about LAYTRANS, but i cant find that command ( I have AutoCAD LT, maybe that's the reason).
Solved by pendean. Go to Solution.
I looked at that option, I can copy layers through design center, the problem is, I already have same layers in the old file. So - I can't copy layers, because they already exist in the file and they have objects in them, so I cant delete them. I guess I want to replace just properties in the same layers. Layer state only copies state as in visible/ lock/ freeze.
AutoCAD rule #1 that's been around forever: content already defined in your DWG file is NEVER replaced by content you import from other files. So yes, if that is the case in your files then those solutions do not work.
I believe the same link (or was it another) that suggested using the above rule to your advantage: insert your "broken" file into the other "perfect" file instead, then SAVEAS to have it all set the way to eventually want it.
Give it a try: and never forget that #1 rule.
thanks for reminding me 😁
I was hoping there was a better solution, but I guess this will work.
