COPY ISSUE
COPY ISSUE
COPY ISSUE
cadffm
the answer is 42, but was is the issue and question in detail?
Sebastian
I did find that my transparency settings had been altered and so I was having difficulty seeing anything! I discovered it while copying.
so, this issue appears to be fixed for now. I appreciate your help!
cadffm
"When I copy a text in a file and paste it to a new location within the open file,  the text is behind the background or the color is severely dimmed such that I cannot see the text behind the background. I have changed back ground color and this does not change the issue.  I have checked my preferences and they are correct.   Does any one have an idea of a setting or a solution I am missing here? I use ACAD LT version 2018?"
Can you share the target file (with the pasted text)?
Sebastian
cadffm
Iit's solved, ok.
Sebastian
