Hey all,
I had something very disconcerting happen yesterday that I can't figure out and if I don't figure it out, I'm not sure how I can trust ACAD anymore.
I'm presently drawing a floating staircase and the math has indicated a 7" riser height for all except the first one which will be 7-1/8". When I dimension from finished floor to top of first thread, it displays 7-1/4". Thinking it was me, I re-calc-ed twice and double checked other riser dims and they all show 7". So, it ain't me.
If you look at my attached pic, you will see that when I select the Dim, the property window at left shows a measurement of 7-1/8". The two other inserts show results from the measure tool and that my drawing units is set to show 1/16ths.
Any thoughts?
AutoCAD LT 2012
Win 7 64 bit
thanks, Bob
