AutoCAD LT Forum
Copy and Paste Scrambles Drawing
9 REPLIES 9
Message 1 of 10
ethanRB8PA
1343 Views, 9 Replies
Hi, Why do my drawings keep scrambling when being copied and pasted!
I have found that purging, then regenerating allows me to then paste a separate drawing into the current dwg.
However, this is only allowed once! On following trials the pasted drawing gets scrambled and unworkable.
Does anyone know how to solve this??
Please Help...
AutoCAD LT 2021: Windows 10
Tags (1)
9 REPLIES 9
Message 2 of 10
cheryl.buck
in reply to: ethanRB8PA
Hi @ethanRB8PA,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I am sorry to hear this is happening. It would be difficult to give a specific reason without seeing the file, but from the screen shots you provided it looks like there is either content in the drawing that AutoCAD LT does not recognize (for example: from one of the AutoCAD toolsets or a third party application) or possibly file corruption.
See the following for more information on How to repair corrupt AutoCAD files.
Can you provide the files and more information to help us understand in what way it is getting scrambled?
If a post answered your question or resolved the issue, please click the Accept Solution button.
Likes are always welcome.
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 3 of 10
pendean
scrambling? Elaborate please, all I see different between your screenshots is possible extra content in #95, but I also noticed you erased 615 objects too.
Message 4 of 10
ethanRB8PA
in reply to: cheryl.buck
Hi @cheryl.buck
Thanks for your response!
I had a read through the corrupt files page and attempted the troubleshooting techniques,
however I still can't find a solution.
I've managed to put a clip together demonstrating the problem and uploaded the files used.
Hope this helps to elaborate.
Thanks again.
Ethan
Message 5 of 10
steven-g
The problem is the block names. You  have the same block names in both drawings and qhen you paste a block into a drawing it uses the block definition that is already existing in the drawing.
Message 6 of 10
ethanRB8PA
in reply to: steven-g
Aha. Thanks Steven!
Is there a way to prevent this from happening without having to change the block definitions??
Thanks again
Ethan
Message 7 of 10
hwalker
Rename the block in the destination drawing OR redefine the block see the link below
Solved: REPLACING OLD DYNAMIC BLOCK WITH NEW DYNAMIC BLOCK AT SAME SCALE,HEIGHT,WIDTH AND INSERT POI...
Howard Walker
Left Handed and Proud
Message 8 of 10
leslie.lees
You'd need to remove all instances of the old block, purge the dwg (look in the list to see it's purging the old block name), then you can re-insert the (copy & paste even) the block again, or rather your updated version of the same block.
Message 9 of 10
steven-g
Unfortunately no simple way. I only looked at one block 'scale22' which is the most visible. The problem is it is used in both drawings and it has a different visual appearance in both versions. So your only option in cases like that is to rename one of the blocks before you copy and paste it. It really is down to just careful naming conventions for your blocks. If you use similar names every time then eventually you end up with situations where two different blocks, unfortunately, end up with the same name, and the problem only shows up in situations like this. WHich in a worst-case scenario could actually go unnoticed but show the wrong information.
L T doesn't have any tools to deal with this problem it is just a case of good housekeeping.
Message 10 of 10
ethanRB8PA
Hi @steven-g
Your replies have been such a great help.
Thankyou!
Ethan
Technology Administrators
