Email address Sent From: field
jkish
Observer Observer
jkish
Observer
Observer
Recently upgraded to Autocad lt 2022 Along with getting a new computer. Now when i email a drawing through autocad the from email address is not the one i want to send from. I have both a Home and Shop address, it keeps defaulting to the home address. Tried to resolve this but no luck
rkmcswain
As a workaround, save the DWG file, then open your email app, and email from there.
Have you opened a support ticket with Autodesk?
    • Here are the various Autodesk support offerings. You may need to be logged into your Autodesk Account in order to see an accurate list of the options available to you.
R.K. McSwain     | CADpanacea | on twitter
vladimir_michl
There is no AutoCAD-specific setting for this. AutoCAD just uses your default mailer to send DWGs over e-mail. You can set multiple user profiles e.g. in your MS Outlook. Or save and send your DWG manually as e-mail attachment. Or better yet, share them online using the SAVETOWEBMOBILE function (e-mail attachments are a rather outdated method).
Vladimir Michl, www.arkance-systems.cz - www.cadforum.cz
jkish
Observer
Observer
Thanks For the replies
Was hoping for and easy solution to return to prior to upgrade status
Will contact autodesk or the it people and will post results
John Kish
pendean
Community Legend
Community Legend
>>>...it keeps defaulting to the home address...<<<
That is nothing AutoCAD/LT controls: that is your default email app's settings.
Contact your email software support for help assigning the correct account to your default.
