AutoCAD LT Forum
Welcome to Autodesk’s AutoCAD LT Forums. Share your knowledge, ask questions, and explore popular AutoCAD LT topics.
convert .edrw to dwg
10 REPLIES 10
Message 1 of 11
41512 Views, 10 Replies
Received .edrw file and wonder how to open it in AutoCAD LT?
10 REPLIES 10
Message 2 of 11
rkmcswain
You'll have to get the Solidworks user to export to some format that AutoCAD LT can open, such as .DWG, or .DXF
R.K. McSwain     | CADpanacea | on twitter
Message 3 of 11
john.vellek
HI @Anonymous,
If you can't get a different file format, you can open Solidworks files (SLDDRW, SLDPRT , SLDASM) in Fusion 360 and then you could move to AutoCAD dwg's
Of course you will be able to see the 3D in AutoCAD LT but you wont' be able to do any 3D editing.
Please select the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 4 of 11
john.vellek
Hi htung,
I am checking back to see if my post helped you with your problem. Please add a post with your results so other Forum users can benefit.
Please hit the Accept as Solution button if my post fully solves your issue or answers your question.
John Vellek
Message 5 of 11
JDMather
in reply to: john.vellek
@john.vellek wrote:
... you can open Solidworks files in Fusion 360 and then you could move to AutoCAD dwg's
I don't think this will work.
A SolidWorks eDrawing  (*.edrw) is a web viewing format similar to Autodesk *.DWFx.
Message 6 of 11
john.vellek
in reply to: JDMather
Hi @JDMather,
Thanks for the clarification on the edrw issue.
It would be interesting to try working with a file if I could get one.
John Vellek
Message 7 of 11
pendean
samples here, search EDRW http://www.3dvia.com/warehouse
Message 8 of 11
JDMather
Prior to posting -
I tried with eDrawing - couldn't get it to work
SolidWorks drawing file *.slddrw - couldn't get it to work
SolidWorks part file *.sldprt - that worked
(the files attached)
Message 9 of 11
john.vellek
Hi @JDMather,
I concur worth your results. I have been able to open the .SLDPRT in Inventor but that's the extent of my success.
So, IMHO, I would say that if there is a conversion to be done it likely needs to be done on the Solidworks side and not in AutoCAD LT.
Thanks for your contribution.
John Vellek
Message 10 of 11
rkmcswain
In other words, see post 2.
Message 11 of 11
john.vellek
in reply to: rkmcswain
Absolutlely!  Thanks
John Vellek
Forma Design Contest
Technology Administrators
