Convert block or polyline into a custom hatch pattern.
Mrijzewijk
Message 1 of 16
Mrijzewijk
is there a way to convert a block or polyline into a custom hatch pattern ?
I want to creat a view of a roof, filled with a type of rooftile only found here in the Netherlands.
Thanks for your help.
Best regards,
Marcel
Replies (15)
Message 2 of 16
steven-g
Not in LT, you can certainly create a custom hatch, but they consist of line segments only. If you want to use a block of a roof tile then maybe look at the array command (but that will only use full blocks - no halves at the edges).
How much detail do you need/want to show in the hatch, would it not be possible to just adapt an existing hatch.
Message 3 of 16
Mrijzewijk
I made a dynamic block with an array option and clipped it so size, which works fine.
But it seems to me that hatch is a better option.
Not much detail, a simple single line block should be more then enough,
Adapting an existing hatch might work, although i haven't found a suitable pattern yet.
Thanks for the tip !
Message 4 of 16
steven-g
Can you show us an image? A single line block is very simple.
Message 5 of 16
Mrijzewijk
Here are 3 types i did earlier, with a double line at the bottom.3xrooftile3xrooftile
Message 6 of 16
steven-g
A hatch can only contain lines, so no curves, you would need to break those curves down into short line segments to create a hatch pattern like that. Have you tried a google search here's just one site offering free roof tile hatches
Message 7 of 16
Mrijzewijk
Ok thanks, i will have a look.
Message 8 of 16
hugha
The hatch would need to depict properly sized tiles as laid.
Could you post a full-scale R14 DXF of the tiles (curves and polylines are ok)?
best,
Hugh Adamson
www.hatchkit.com.au
Message 9 of 16
Mrijzewijk
@hugha , sorry, i can only save to R12 in LT 2021 (or so it seems.)
Message 10 of 16
pendean
Community Legend
Community Legend
R0012DXF is lower than R14DXF, so saving it further down should work just fine.
Message 11 of 16
Mrijzewijk
For some reason i can not add an attachment
So used a wetransferlink: https://we.tl/t-LNTu40uvv3
Thanks again.
Message 12 of 16
hugha
Ok, DXF shows three individual tiles in plan so have sizes if leftmost tile is ~218 wide.
However each must be trimmed to hide what's hidden.
How does each overlap
  • vertically?
  • horizontally?
best,
Hugh
Message 13 of 16
Mrijzewijk
@hugha
There is no overlap.
A finished hatch should look something like this.
Bottom row is a simplied version without the double line.
Best regards,
Marcel
Message 14 of 16
hugha
thanks, that simplifies the job.
See attached for double lined versions butted both ways.
hth,
Hugh Adamson
www.hatchkit.com.au
Message 15 of 16
Mrijzewijk
@hugha
Thanks a lot.
Tile 2 looks quit good.
How did you make the patterns ?
Best regards,
Marcel
Message 16 of 16
hugha
It's straightforward:
1 open DXF in HatchKit,
2 drag Entities into three separate pattern editing windows
then for each:
3 delete other than target tile
4 arrange, butting tiles at top and sides
5 remove unnecessary repeated lines
6 save to named .PAT
That's it.
hth,
Hugh Adamson
www.hatchkit.com.au
