Closing an open viewport
JamesPowell7164
Message 1 of 12
JamesPowell7164
Hello my fellow AutoCAD aficionados,
I have told all in my organisation to "lock" viewports when they have set the viewport scale. Thus, when they mistakenly open a viewport they can zoom out and click out side the boundary to close it. Being in the infancy of use, some people forget this simple task and do not lock the viewports. So, I have a stream of new users that are working in model space, creating viewports in paper space, they then proceed to double click in viewports without being able to see the boundary of the viewport and so are stuck in limbo.
Is there a way to close an open viewport if you cant see the boundary to click outside of?
I hope that makes sense.
Replies (11)
Message 2 of 12
Use "PSPACE" command to get out on an open viewport.
Try it!
Cheers!
Message 3 of 12
h_s_walker
Or if they have the taskbar at the bottom, when they're in model space it should say MODEL, just click on that and it will change to PAPER and they're now in paperspace
Howard Walker
Left Handed and Proud
Message 4 of 12
steven-g
And another one for the list "_vpmin" (_vpmax to go into a full viewport), this is also one of the icons on the lower right of the screen, with a handy set of direction arrows to skip between available viewports within a layout, though the icon itself can be turned on/off with the "viewport maximize" in the application status bar menu settings.
Message 5 of 12
JamesPowell7164
Thanks pal
Message 6 of 12
JamesPowell7164
Hi Howard
The particular person was n paper space and had opened a viewport without locking it. she zoomed in and then doubled clicked which opened the viewport. Whilst the model tab was open to her she couldn't close the viewport to zoom back out. I am not sure your suggestion works.
Message 7 of 12
JamesPowell7164
Hi Steve
I found the viewmax and viewmin icon but didn't find the other "ARROWS" that you speak of.
See attached screenshot
Message 8 of 12
h_s_walker
Bottom left hand corner of that screenshot says MODEL. If you click on that it changes to PAPER and you'll be back in paperspace no matter if you're zoomed in or not.
Howard Walker
Message 9 of 12
pendean
Community Legend
Community Legend
This is a button: click on it, it changes name to/from PAPER/MODEL and changes 'spaces' too, no need to remember command names
Message 10 of 12
JamesPowell7164
Dean
thanks for your help but I don't think I explained myself very well.
The operator was in paper space and had zoomed so that the limits of the viewport were not visible. THEN she double clicked by accident and opened the viewport. Because she couldn't see the edges of the view port she couldn't click outside it to close the viewport and thus zoom out.
The pspace command seems to do the trick.
Let me know if that makes any sense at all - thanks for your help again though.
Message 11 of 12
JamesPowell7164
DOH!!!!!!!!!!
I see now - I was looking at the wrong "MODEL" button. I was looking at the model tab.
How could I ever have doubted you!! lol
thanks to all that have contributed to this post.
Message 12 of 12
cosminchirilut
Community Visitor
Community Visitor
This method works as well as the pspace command. When you double click on a viewport in paper space you open the viewport wich means you pass to model space in paper space, and by clicking on MODEL tab you pass back to paper space and will be able to zoom out again. Hope it is coherent enough.
