Hi all,
I don't recommend renaming .exe files.
The reason for that is other .exe files will most likely make a call to the one you just renamed. When this happens it will again have a performance issue again or worse, an error message.
It is better to disable the functionality by not installing it if possible.
I suspect The multiple instances of the Desktop App is because I have multiple Autodesk programs installed and the Desktop App finds all the different programs and shows them to you, hence multiples instances.
I would not delete/rename them or end those processes. If you really have problems with it then here's what I'd do.
1) Stop the Autodesk Desktop App and uninstall it. You will not be able to download/install service packs and hot fixes nearly as easy, but you won't see multiple instances of the AcWebBrowser either.
2) Uninstall all Autodesk programs and install them again BUT ensure you deselect anything that has 360 in its name, this means you'll need to expand out the selections for things like AutoCAD, Architecture or Civil3D, etc, Also ensure in the sub-configurations you not only disable anything 360 but also anything that refers to the internet or a website, like the Exchange, Uncheck A360. Deselect the Desktop App and/or Application manager.
3) Go into the Autodesk program and tell it to use Offline Help. There may be an option during the install too.
That all being said, some Autodesk functionality will still need to access things within a local webpage as things like Help are web-based and typically come up in a web-type interface.
Best regards,
Jeff Lotan
Sr. Tech Support Specialist
North America Solution Center
IMAGINiT Technologies
T: 888.528.4765
Email:
[email protected]www.imaginit.com
Have a great day!
Jeff Lotan
Sr. Technical Support Specialist
T: 888.528.4765
