Hi, I'm sure this is a simple one but can't seem to find answer on the forum or help.
I want to change the functions that appear when I mouse right click. I get lots of standard options like draw order, pan, zoom, etc which I simply don't use in this way. I primarily want to use copy, paste, rotate, scale. Is there a way to delete those functions I don't use?
Cheers
Solved by hwalker. Go to Solution.
At the command line type CUI. Expand the tree in the image below, and you can add and remove what you want
Howard Walker
sorry - should have mentioned I am using a Mac (AutoCAD 2019) so when I enter CUI I only see the attached image
Post your question again in the MAC forums. The link is below
Howard Walker
