Hi
I am just wondering how to permanently change some default utility settings.
When I open a new drawing my unit precision is automatically set to 0.00.
Now to change this I go to the Application Menu Button -- Drawing Utilities -- Units -- And then change the precision to whatever I want, thats ok.
But is there any way to make this change my permanent default, instead of having to change it everytime I open a new blank drawing
P
>>When I open a new drawing my unit precision is automatically set to 0.00"
0.00 ? So you already use a "template" drawing to create new files and this is the right way.
What you have to do: Create or edit the template file for your needs!
For example: New drawing, change LUPREC/AUPREC to your needs, save the file as *.dwt
And optional, set the quicknew setting to this file
[F1] QNEW
OPTIONS/FILES/ search for the path for QNEW
>>"But is there any way to make this change my permanent default,"
Diese Einstellung wird in jeder Datei gespeichert. Gehen Sie also für neue Dateien wie oben beschrieben vor.
Sebastian
@padraig.gaughanH3RYD Permanent? In AutoCAD/LT, you can user can get close to that with one or more of these methods:
Thanks, I just entered in ChattGPT and it gave me this (which worked):
In AutoCAD LT, you can set your preferred unit precision as the default by modifying the template file that is used when creating a new drawing. Here are the steps to do this:
Open AutoCAD LT.
Change the unit precision to your preferred settings using the steps you mentioned: Application Menu Button > Drawing Utilities > Units.
Once you have set the units to your liking, type "SAVEAS" in the command line.
Choose a location to save the file and give it a name, such as "DefaultTemplate.dwt". Make sure to select the file type as "Drawing Template (*.dwt)".
Save the template file in a location where AutoCAD LT can easily access it. A common location is the Templates folder within the AutoCAD LT installation directory.
Now, you need to tell AutoCAD LT to use this template as the default when creating new drawings. To do this, go to the Options dialog:
Look for the "Template Settings" section, and under "Default Template File Name for QNEW," browse to and select the template file you just created (e.g., DefaultTemplate.dwt).
