I am unable to save my work because I get this message when I try to save:
"QAVE not allowed during reference editing".
If I try to close the REFEDIT session and save changes, it says "Cannot save back changes because objects in the working set reference objects outside the working set"
Solved by tmccar. Go to Solution.
I discovered that I had started editing a title block a while back and had not ended that REFEDIT session. The I inserted some jpeg images and it was these that caused the problem. When I deleted them, I was able to close my REFEDIT session and save the changes. The only issue was, the whole drawing was a block and dimension scale was way off. But it was back to normal when I exploded it.
I was also trying to save changes to a Block and kept getting the following message.
"Cannot save back changes because objects in the working set references objects outside the working set. The Refedit session is still active. Press F2 after dismissing the dialog to see the list of missing references."
After having a closer look, I realized that there was still an inserted PDF, within the block I was trying to save, which was small in size compared to the rest of the block, which was hard to see. Once I deleted it, I was then able to save the block.
