Every once in a while ACAD LT will not allow me to move my UCSICON to a new location. It will just want to draw a window and not select anything. I end up having to close the file and re-open. It will then work but will eventually act up again.
Any ideas? Thanks in advance.
Solved by ryan.bales. Go to Solution.
Are you talking about the UCS command?
Yes. Often times I have to move the UCSICON to a different location for dimensioning.
Hmm i've never seen that happen in LT. Maybe with full ACAD and dynamic UCS.
When it happens again can you post a screenshot of it?
I can try to screen shot it. It's kind of one of those things where it won't select it. Say I drag my cursor over the icon to select it. Normally it would highlight with 3 blue boxes at the ends of the icon. When it isn't working, it will not select anything and goes into a mode that just draw a box as if you were going to select geometry.
Not sure what you mean by "not enough"? It's set to ON. The size is at the default setting (50?). I would think if it's a setting it would be more consistent and do it all the time. Don't know. Guess I'll learn to live with it and just keep re-booting when I need to. Thanks for all the help.
When I type in UCSICON in the command line a window pops. I have it ON and SELECTABLE is set to YES. I see nothing for LOCATION other than the options I've listed. Reading the help, it says I can just select the icon and move to where I would like. What puzzles me is that the issue comes and goes. I could be working on the same file all day and it will be working fine and then all of a sudden it will no longer allow me to change the location to where I want it.
Reading back over your posts, this might be the problem, you cannot select the icon with a window, you have to phsically click one time on the icon whilst the cursor is over it, could it be that sometimes you are clicking next to it and you get the window selection starting, and at other times you do just happen to click when the cursor is over the icon and it then works as you expect.
There is a lot of possibilities for what it could be if it comes and goes. You could simply use the UCS command to move it - that is basically what is happening you when you select it and pick the grip to move it anyway.
Correct. This is the issue. It will not allow me to pick the icon or grips. When I try to, it goes into a "box" mode if that makes sense.
If you reset it to world does it allow you to pick it?
Unless you are running an old LT version, UCSICON here has these location options
which mean the following in HELP
>>>...then all of a sudden it ...<<<
As noted by others, you are either not selecting it, missing, and the program assumes you want to window, or your UCSICON is set to be non-selectable in the file you are in. Next time that happens, go into UCSICON, then SELECTABLE, and see what it is set to.
Same screen I have. I'll check the settings next time it happens. Not sure why they would change though? Thanks!
