Buttom added to quick access toolbar disappear !
perBF9V7
Message 1 of 8
perBF9V7
Hi
Every time at add Export buttom (PDF) to quick access toolbar, by right click and hit add to Quick acces toolbar, it disappear every time i restart Autocad.
Anyboddy have a soloution for this ?
Per Esrup
Replies (7)
Message 2 of 8
cadffm
>>"by right click and hit add to Quick acces toolbar"
Never saw this. Where are you and where do you click?
Screenshots welcome
>>"Anyboddy have a soloution for this ?"
Seems you have a problem with
1. your write access to your .cuix files
 OR
2. There is a Admin Cadmin or PlugIn, what forces to overwrite your custom data.
Check this out:
Restart Acad, OPTIONS/FILES/Customizazion Files/Main Customizazion File/
Copy this path (up to the last slash / the characters after that NOT)
if standard path, looks like this
C:\Users\<yourid>\AppData\Roaming\Autodesk\AutoCAD 20nn - English\Rnn.0\enu\Support
WinExplorer
And paste the path to your WinExplorer,
check out the 'last modified date' of your main cuix file,
61seconds since Acad start gone? good
In Acad:
Add your button again to QAT
In WinExplorer
check out the main cuix file ' last modified date' time.
Is it update to now?
okay.
Close Acad
still a new updated time ?
Double-click a .dwg file in WinExplorer
New QAT button missing again?
Sebastian
Message 3 of 8
pendean
Community Legend
Community Legend
@perBF9V7 You probably need to use WSSAVE command to save your workspace(s) where you added to the QAT in that way. If that does not help, your Windows login might be too restrictive or your LT installation is corrupt.
Message 4 of 8
pendean
Community Legend
Community Legend
@cadffm It's been around forever, see example below with ARRAY in the Ribbon
Message 5 of 8
perBF9V7
Hi Sebastian, If i check the update of cui file, it seems to work properly, i can see the newly update date and time,  if i make a change, but when i close Acad it don't change the file again.
Anyway if i add some other command to the QAT, i works fine, so maybe it could be the Export command, because there a 3 options to export DWFx, DWF, PDF,,
Per
Message 6 of 8
perBF9V7
Hi
It works with other commands, so i think the installation are ok.
Per
Message 7 of 8
cadffm
thanks for sharing this important informations
1. "Anyway if i add some other command to the QAT, i works fine"
2. WHAT in detail you added
Yes, it's because what kind of item you added (I don't know why it works to add, it should be blocked).
Question: Your title is about PDF, so all what you want is the Export to PFD button, NOT all three / the whole FLYOUT ?
Solution: Add the right button only:
Open QAT menu and select "More Commands..." option
Now in CUI command dialog, filter for EXPORT to PDF (lower left part of dialog / Commands)
now - drag&drop this item to your QAT
close CUI command, close Acad, restart Acad, be happy!
Sebastian
Message 8 of 8
perBF9V7
Hi
Thank you, works great.
 Per
