>>"by right click and hit add to Quick acces toolbar"
Never saw this. Where are you and where do you click?
Screenshots welcome
>>"Anyboddy have a soloution for this ?"
Seems you have a problem with
1. your write access to your .cuix files
OR
2. There is a Admin Cadmin or PlugIn, what forces to overwrite your custom data.
Check this out:
Restart Acad, OPTIONS/FILES/Customizazion Files/Main Customizazion File/
Copy this path (up to the last slash / the characters after that NOT)
if standard path, looks like this
C:\Users\<yourid>\AppData\Roaming\Autodesk\AutoCAD 20nn - English\Rnn.0\enu\Support
WinExplorer
And paste the path to your WinExplorer,
check out the 'last modified date' of your main cuix file,
61seconds since Acad start gone? good
In Acad:
Add your button again to QAT
In WinExplorer
check out the main cuix file ' last modified date' time.
Is it update to now?
okay.
Close Acad
still a new updated time ?
Double-click a .dwg file in WinExplorer
New QAT button missing again?
