In model space, I am having a hard time seeing my lines against the black back ground. I just installed autocad lt 2019 on a new machine and I imported my favorite CTB files to get my line weights. I draw a lot with white, blue, magenta and various grays. I love my line weights! But on the new machine I can barely see them on the screen. They are too dim...not bright enough. Is there a contrast setting in autocad lt? Can I make the lines and objects more visible on the model screen? Going crazy looking for options. Thanks!
Solved by sophia_lee. Go to Solution.
Solved by pendean. Go to Solution.
if it's a general CAD issue ... have you try to play with the Brightness mode of your machine . or disable hardware acceleration from GRAPHICSCONFIG .
Imad Habash
Hi @Anonymous ,
Thanks for posting.
I had a similar case where the lines are far too dim. I fixed it by updating the graphics card driver version. Take a look at the Autodesk Knowlede Network article below;
Please "Accept Solution" if a reply or replies have helped resolve the issue or answered your question, to help others in the community.
Yes, thanks!
I just had to adjust my model background color to black. For some reason, this version of AutoCAD light comes standard with a grey background in model space.
I've had the same problem since I bought a new computer and a new screen. I'm using a NVIDIA graphic card & Autocad LT 2021, with black background. I feel like a can't see anything and my eyes are getting so tired... The lines seems faded and so thin.
Any suggestions?
Thanks!
Hi @arcand_lucie ,
I would rather recommend to change the NVIDIA setting to perform high performance to run AutoCAD and set the
Hope this is helpful.
Please accept this as solution if this helps to resolve your issue.
thank you,
Hi @sophia_lee ,
I had already forced AutoCAD to use my NVIDIA graphics card months ago. Althought, I had not changed the settings of the card, as shown in your link, which I finally did last week. I think the lines actually look brighter.
perfect solution. not sure but it seemed liked I needed to re-start the program for it to take effect
