All of the blocks that I created are no longer inserting. I'll go to the "Tool Palettes" and select a block to insert. Then when I bring my cursor to the drawing space there's nothing to insert. It asks me to select an insertion point, but after I click anywhere nothing appears.
This started today and I haven't changed any settings on any of my drawings. Blocks I've imported from downloaded drawings still work. The properties of my blocks are the same as the properties of the blocks that I've imported. When creating a block I've been drawing, grouping, selecting "Create Block", giving it a name, saving my .dwg file, then dragging the block into the tool palette.
What am I doing wrong!?
Solved by pendean. Go to Solution.
Solved by cadffm. Go to Solution.
Please start a new file, base on ACAD.DWT (or ACADISO.DWT for metric)
Try it again ONE TIME
Press the tool button and when Acad ask for insertion point, click a point or type in 0,0.
Is there a message? Press [F2] toread what ACAD said.
Nothing?
Type-in
ZOOM <enter>
EXTENTS <enter>
can you see your Block now?
if not:
Press [CTRL]+[A]
What is the feedback? [F2]
Sebastian
Solved! Somehow the base point on all of my created blocks was changed somehow. When I would insert them they would appear WAY off screen. I went in and changed their base points back to where they should be and it's working fine. Thanks for the suggestion to zoom out. Still no clue how they all got changed.
