Block calculating values from its attribute
I'm trying to create block which would calculate some values.
In fact I want to input Volume of an object and get it weight and mass calculated automatically
I've tried using combined FIELD - FORMULA and OBJECT VALUE expressions but all I can get is error "####"
When I want to get simple Value from block attribute and also it didn't give any result.
When I've exploded this block FORMULA worked fine.
Do You know any solution for that problem?
Or maybe any post that I've missed could give me a hint?
Thanks in andvance for Your time.
Tomasz
steven-g
Can you post a copy of the block ?
Is it a dynamic block, fields in a dynamic block will only show the values in the block definition !
Where are values (objects) your fields refer too - in the block? in attributes? in variables?
Or are your fields within an attribute?
The answer will vary depending on the situation, seeing the block will make answering much easier.
Emmsleys
To best resolve your thread it would be helpful if you provide some additional information.
Please add a post with your status.
Sarah Emmsley
Technical Support Specialist
Thanks for support, just forgot to reply.
As I remember I followed one of Your posts with example dynamic block.
I just added a visibility state and it solved the problem.
